[GRASS-dev] compile 6S library in GRASS
Moritz Lennert mlennert at club.worldonline.be
Wed Jun 27 05:01:14 PDT 2018
On 27/06/18 13:54, Roberto Marzocchi wrote:
> Il giorno mer 27 giu 2018 alle ore 13:47 Markus Metz
> <markus.metz.giswork at gmail.com <mailto:markus.metz.giswork at gmail.com>>
> ha scritto:
>     Hi Roberta,
>     On Wed, Jun 27, 2018 at 1:20 PM, Roberta Fagandini
>     <robifagandini at gmail.com <mailto:robifagandini at gmail.com>> wrote:
>      > Hi all!
>      > I need to compile the 6S library in GRASS in order to install the
>     python library Py6S [0].
>     do you really need Py6S? Can't you use i.atcorr instead?
> She use Py6S to calculate imput for i.atcorr
That seems a bit overkill: why use Py6S to then use i.atcorr ? What are
you trying to get from Py6S ?
Moritz
