[GRASS-dev] compile 6S library in GRASS
Stefan Blumentrath Stefan.Blumentrath at nina.no
Thu Jun 28 05:03:24 PDT 2018
Just one quick follow up question regarding your wild guess:
With a raster map option, the module would have to make assumptions on units / scale of values in the map (documented in the manual), so in the further process e.g. average or median could be extracted (r.univar) and fed to 6s input file, right?
Cheers
Stefan
From: grass-dev <grass-dev-bounces at lists.osgeo.org> On Behalf Of Yann Chemin
Sent: torsdag 28. juni 2018 13:38
To: mlennert at club.worldonline.be
Cc: Markus Metz <markus.metz.giswork at gmail.com>; GRASS-dev <grass-dev at lists.osgeo.org>; Roberta Fagandini <robifagandini at gmail.com>
Subject: Re: [GRASS-dev] compile 6S library in GRASS
a wild guess: specify a raster input option for AOT (alongside other options), let user find its image source and use it.
Very limited requirement for the GSoC student, most latitude for the the modules user.
Dr. Yann Chemin
Freelancer
+33 7 83 85 5234
3 Toulmelin, 56400 Plumergat, FR
https://www.paypal.me/yannchemin
On Thu, 28 Jun 2018 at 13:35, Moritz Lennert <mlennert at club.worldonline.be<mailto:mlennert at club.worldonline.be>> wrote:
On 28/06/18 12:17, Roberta Fagandini wrote:
> I'm not an expert in MODIS data so if someone wants to give
> suggestions about how to retrieve the AOT from these data, I will
> definitely add this option too.
I'm not an expert, and MarkusM can probably provide you with more info,
but you can already see https://lpdaac.usgs.gov/node/1265.
Moritz
grass-dev mailing list
grass-dev at lists.osgeo.org<mailto:grass-dev at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20180628/07787481/attachment-0001.html>
