[GRASS-dev] [GRASS GIS] #2998: m.nviz.image fails with X Error BadValue integer parameter out of range for operation
GRASS GIS trac at osgeo.org
Sat Jun 30 02:27:55 PDT 2018
operation
  Reporter:  wenzeslaus  |      Owner:  grass-dev@…
      Type:  defect      |     Status:  reopened
  Priority:  normal      |  Milestone:  7.2.4
 Component:  LibOpenGL   |    Version:  svn-trunk
Resolution:              |   Keywords:  m.nviz.image, NVIZ, 3D, GLX,
                         |  X_GLXCreateContext, g.gui.animation
       CPU:  x86-64      |   Platform:  Linux
Changes (by neteler):
 * status:  closed => reopened
 * resolution:  fixed =>
Comment:
 Replying to [comment:11 hcho]:
 > r72939 should fix this issue. Indirect rendering is disabled by default
 since Xorg 1.17. Nviz now uses direct rendering. If we need to support
 indirect rendering, we can add an environment variable later.
 (reopening for potential backport to 7.4/7.2)
Ticket URL: <https://trac.osgeo.org/grass/ticket/2998#comment:13>
