[GRASS-dev] Fwd: [Proj] PROJ 5.0.0 Released
Helmut Kudrnovsky hellik at web.de
Thu Mar 1 23:48:21 PST 2018
Some migration hints:
https://kbevers.github.io/development/migration.html
Markus Neteler wrote
> FYI
> ---------- Forwarded message ----------
> From: Kristian Evers <
> kreve@
> Date: Thu, Mar 1, 2018 at 9:10 PM
> Subject: Re: [Proj] PROJ 5.0.0 Released
> To: "PROJ.4 and general Projections Discussions"
> proj at .maptools
> announce at .osgeo
> announce at .osgeo
> Dear all,
> We are pleased to announce that PROJ 5.0.0 has been released!
> This is the first major release of PROJ in over 25 years. The new release
> brings
> many updates including a new API, much improvement geodetic capabilities
> and
> a long list of bug fixes. The full release notes is included at the
> bottom of this mail.
> The documentation has been given a significant overhaul for this new
> release.
> Check it out on http://proj4.org/.
> The source distributions can be download here:
> http://download.osgeo.org/proj/proj-5.0.0.tar.gz
> http://download.osgeo.org/proj/proj-5.0.0.zip
> In addition to the new version of PROJ, updated datum grids packages has
> been
> released. On top of the existing proj-datumgrids package we have added
> regional
> packages with additional grids and init-files that are not essential to
> the
> functionality of PROJ, but very useful for PROJ users in those specific
> regions.
> More information on the datumgrid packages can be found at the GitHub
> repository:
> https://github.com/OSGeo/proj-datumgrid
> Download the packages here:
> http://download.osgeo.org/proj/proj-datumgrid-1.7.tar.gz
> http://download.osgeo.org/proj/proj-datumgrid-europe-1.0.tar.gz
> http://download.osgeo.org/proj/proj-datumgrid-north-america-1.0.tar.gz
> http://download.osgeo.org/proj/proj-datumgrid-oceania-1.0.tar.gz
> Thanks to everyone who has contributed over the last year and a half
> to make this
> release of PROJ happen.
> The PROJ development team.
> 5.0.0 Release Notes
> This version of PROJ introduces some significant extensions and
> improvements to (primarily) the geodetic functionality of the system.
> The main driver for introducing the new features is the emergence of
> dynamic reference frames, the increasing use of high accuracy GNSS,
> and the related growing demand for accurate coordinate
> transformations.  While older versions of PROJ included some geodetic
> functionality, the new framework lays the foundation for turning PROJ
> into a generic geospatial coordinate transformation engine.
> The core of the library is still the well established projection code.
> The new functionality is primarily exposed in a new programming
> interface and a new command line utility, "cct" (for "Coordinate
> Conversion and Transformation").  The old programming interface is
> still available and can - to some extent - use the new geodetic
> transformation features.
> The internal architecture has also seen many changes and much
> improvement.  So far, these improvements respect the existing
> programming interface. But the process has revealed a need to simplify
> and reduce the code base, in order to support sustained active
> development.
> !!! Therefore we have scheduled regular releases over the coming years
> !!! which will gradually remove the old programming interface.
> !!! This will cause breaking changes with the next two major version
> !!! releases, which will affect all projects that depend on PROJ
> !!! (cf. section "deprecations" below).
> The decision to break the existing API has not been easy, but has
> ultimately been deemed necessary to ensure the long term survival of
> the project. Not only by improving the maintainability immensely, but
> also by extending the potential user (and hence developer) community.
> The end goal is to deliver a generic coordinate transformation
> software package with a clean and concise code base appealing to
> both users and developers.
> VERSIONING AND NAMING
> For the first time in more than 25 years the major version number of
> the software is changed. The decision to do this is based on the many
> new features and new API. While backwards compatibility remains -
> except in a few rare corner cases - the addition of a new and improved
> programming interface warrants a new major release.
> The new major version number unfortunately leaves the project in a bit
> of a conundrum regarding the name. For the majority of the life-time
> of the product it has been known as PROJ.4, but since we have now
> reached version 5 the name is no longer aligned with the version
> number.
> Hence we have decided to decouple the name from the version number and
> from this version and onwards the product will simply be called PROJ.
> In recognition of the history of the software we are keeping PROJ.4 as
> the *name of the organizing project*. The same project team also
> produces the datum-grid package.
> In summary:
> o The PROJ.4 project provides the product PROJ, which is now at
>   version 5.0.0.
> o The foundational component of PROJ is the library libproj.
> o Other PROJ components include the application proj, which provides
>   a command line interface to libproj.
> o The PROJ.4 project also distributes the datum-grid package,
>   which at the time of writing is at version 1.6.0.
>  UPDATES
>  o Introduced new API in proj.h.
>    - The new API is orthogonal to the existing proj_api.h API and the
>      internally used projects.h API.
>    - The new API adds the ability to transform spatiotemporal (4D)
>      coordinates.
>    - Functions in the new API use the "proj_" namespace.
>    - Data types in the new API use the "PJ_" namespace, with a few
>      historic exceptions such as XY, XYZ, LP and LPZ.
>  o Introduced the concept of "transformation pipelines" that makes it
>    possible to do complex geodetic transformations of spatiotemporal
>    coordinates by daisy chaining simple coordinate operations.
>  o Introduced cct, the Coordinate Conversion and Transformation
>    application.
>  o Introduced gie, the Geospatial Integrity Investigation Environment.
>    - Selftest invoked by -C flag in proj has been removed
>    - Ported approx. 1300 built-in selftests to gie format
>    - Ported approx. 1000 tests from the gigs test framework
>    - Added approx. 200 new tests
>  o Adopted terminology from the OGC/ISO-19100 geospatial standards
>    series. Key definitions are:
>    - At the most generic level, a *coordinate operation* is a change
>      of coordinates, based on a one-to-one relationship, from one
>      coordinate reference system to another.
>    - A *transformation* is a coordinate operation in which the two
>      coordinate reference systems are based on different datums, e.g.
>      a change from a global reference frame to a regional frame.
>    - A *conversion* is a coordinate operation in which both
>      coordinate reference systems are based on the same datum,
>      e.g. change of units of coordinates.
>    - A *projection* is a coordinate conversion from an ellipsoidal
>      coordinate system to a plane. Although projections are simply
>      conversions according to the standard, they are treated as
>      separate entities in PROJ as they make up the vast majority
>      of operations in the library.
>  o New operations:
>    - The pipeline operator (pipeline)
>    - Transformations:
>      + Helmert transform (helmert)
>      + Horner real and complex polynomial evaluation (horner)
>      + Horizontal gridshift (hgridshift)
>      + Vertical gridshift (vgridshift)
>      + Molodensky transform (molodensky)
>      + Kinematic gridshift with deformation model (deformation)
>    - Conversions:
>      + Unit conversion (unitconvert)
>      + Axis swap (axisswap)
>    - Projections:
>      + Central Conic projection (ccon)
>  o Significant documentation updates, including
>    - Overhaul of the structure of the documentation
>    - A better introduction to the use of PROJ
>    - A complete reference to the new proj.h API
>    - a complete rewrite of the section on geodesic calculations
>    - Figures for all projections
>  o New "free format" option for operation definitions, which
>    permits separating tokens by whitespace when specifying key/value-
>    pairs, e.g. "proj = merc lat_0 = 45".
>  o Added metadata to init-files that can be read with the
>    proj_init_info() function in the new proj.h API.
>  o Added ITRF2000, ITRF2008 and ITRF2014 init-files with ITRF
>    transformation parameters, including plate motion model
>    parameters.
>  o Added ellipsoid parameters for GSK2011, PZ90 and "danish". The
>    latter is similar to the already supported andrae ellipsoid,
>    but has a slightly different semimajor axis.
>  o Added Copenhagen prime meridian.
>  o Updated EPSG database to version 9.2.0.
>  o Geodesic library updated to version 1.49.2-c.
>  o Support for analytical partial derivatives has been removed.
>  o Improved performance in Winkel Tripel and Aitoff.
>  o Introduced pj_has_inverse() function to proj_api.h. Checks if an
>    operation has an inverse. Use this instead of checking whether
>    P->inv exists, since that can no longer be relied on.
>  o ABI version number updated to 13:0:0.
>  o Removed support for Windows CE.
>  o Removed the VB6 COM interface.
>  BUG FIXES
>  All bug fix numbers refer to issues indexed at
>  https://github.com/OSGeo/proj.4/issues/
>  o Fixed incorrect convergence calculation in Lambert Conformal
>    Conic. #16.
>  o Handle ellipsoid parameters correctly when using +nadgrids=@null.
>    #22.
>  o Return correct latitude when using negative northings in
>    Transverse Mercator (tmerc). #138.
>  o Return correct result at origin in inverse Mod. Stererographic
>    of Alaska. #161.
>    of 48 U.S. #162.
>    of 50 U.S. #163.
>  o Return correct result at origin in inverse Lee Oblated
>    Stereographic. #164.
>  o Return correct result at origin in inverse Miller Oblated
>  o Fixed scaling and wrap-around issues in Oblique Cylindrical
>    Equal Area. #166.
>  o Corrected a coefficient error in inverse Transverse Mercator. #174.
>  o Respect -r flag when calling proj with -V. #184.
>  o Remove multiplication by 2 at the equator error in Stereographic
>    projection. #194.
>  o Allow +alpha=0 and +gamma=0 when using Oblique Mercator. #195.
>  o Return correct result of inverse Oblique Mercator when alpha is
>    between 90 and 270. #331.
>  o Avoid segmentation fault when accessing point outside grid. #369.
>  o Avoid segmentation fault on NaN input in Robin inverse. #463.
>  o Very verbose use of proj (-V) on Windows is fixed. #484.
>  o Fixed memory leak in General Oblique Transformation. #497.
>  o Equations for meridian convergence and partial derivatives have
>    been corrected for non-conformal projections. #526.
>  o Fixed scaling of cartesian coordinates in pj_transform(). #726.
>  o Additional bug fixes courtesy of Google's OSS-Fuzz program:
>    https://bugs.chromium.org/p/oss-fuzz/issues/list?can=1&q=proj4
>  DEPRECATIONS
>  o The projects.h header and the functions related to it is
>    considered deprecated from version 5.0.0 and onwards.
>     !!!     PROJECTS.H WILL BE REMOVED FROM THE LIBRARY     !!!
>     !!!                 WITH VERSION 6.0.0                  !!!
>  o The nmake build system on Windows will not be supported from
>    version 6.0.0 on onwards. Use CMake instead.
>     !!! NMAKE BUILD SYSTEM WILL BE REMOVED FROM THE LIBRARY !!!
>  o The proj_api.h header and the functions related to it is
>    consided deprecated from version 5.0.0 and onwards.
>     !!!     PROJ_API.H WILL BE REMOVED FROM THE LIBRARY     !!!
>     !!!                 WITH VERSION 7.0.0                  !!!
>  THANKS TO
>  Version 5.0.0 is made possible by the following contributors:
>     Lukasz Komsta
>     Maxim Churilin
>     edechaux
>     dusanjovic
>     Zoltan Siki
>     Tom Fili
>     Nicolas David
>     Mike Toews
>     Micah Cochran
>     Luke Campbell
>     Ilya Oshchepkov
>     Adam Wulkiewicz
>     Jonas Tittmann
>     Mateusz Loskot
>     Etienne Jacques
>     Bas Couwenberg
>     Elliott Sales de Andrade
>     Charles Karney
>     Aaron Puchert
>     Julien Moquet
>     Charles Karney
>     Howard Butler
>     Even Rouault
>     Thomas Knudsen
>     Kristian Evers
> Proj mailing list
> Proj at .maptools
> http://lists.maptools.org/mailman/listinfo/proj
> grass-dev mailing list
> grass-dev at .osgeo
> https://lists.osgeo.org/mailman/listinfo/grass-dev
best regards
Helmut
Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Dev-f3991897.html
