[GRASS-dev] GSoC Project
Luca Delucchi lucadeluge at gmail.com
Tue Mar 6 21:35:00 PST 2018
On 27 February 2018 at 10:29, sharry gill <sharrygill5656 at gmail.com> wrote:
> Hello Luca,
> There will be a tool, in which the user enters the name of the module, and
> select the flags and parameters of the modules, and select which test to be
> done.
> after selecting these option, the user click "Create Test", then their
> will be a python file generated on the desktop, by using the python file
> user can test the module.
> And When the user will enter the module name, the window will extend and
> at the side it will show manual of the module.
ok, but since there are a lot of modules in GRASS it is better if the tool
will be able to work without the user choses. It should be more automatic
possible.
> Thank You
> Supreet Singh
> https://singhsupreet.github.io/
ciao
Luca
www.lucadelu.org
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20180307/8b620bb2/attachment.html>
