[GRASS-dev] pygrass: How to allow Ctrl-C to stop all subprocesses of GridModule
Moritz Lennert
mlennert at club.worldonline.be
Fri Mar 9 00:16:01 PST 2018
Hi Nikos !
Am 9. März 2018 09:01:25 MEZ schrieb Nikos Alexandris <nik at nikosalexandris.net>:
>* Moritz Lennert <mlennert at club.worldonline.be> [2018-03-08 15:05:46
>+0100]:
>>And another question on GridModule:
>>For the same module using GridModule to split the task of edge
>>detection in a raster map into many parallel tasks, when I want to
>>stop the module run using Ctrl-C I get tons of
>>Process PoolWorker-315:
>>Traceback (most recent call last):
>> File "/usr/lib/python2.7/multiprocessing/process.py", line 267, in
>>_bootstrap
>>_bootstrap
>> self.run()
>> self.run()
>> File "/usr/lib/python2.7/multiprocessing/process.py", line 114, in
>run
>run
>> self._target(*self._args, **self._kwargs)
>> File "/usr/lib/python2.7/multiprocessing/pool.py", line 102, in
>worker
>worker
>> task = get()
>> File "/usr/lib/python2.7/multiprocessing/queues.py", line 374, in
>get
>> task = get()
>get
>> racquire()
>> racquire()
>>KeyboardInterrupt
>>and cannot stop the module, even when flooding the input with Ctrl-Cs.
>>Any hint how to allow Ctrl-C to stop all subprocesses ?
>>Moritz
>Moritz, could it be a case related to the ones mentioned in
>https://stackoverflow.com/a/1635084/1172302
>https://stackoverflow.com/a/11816038/1172302
Related yes, but AFAIU GridModule uses multiprocessing, not multithreading. I think it should be possible to modify something in the GridModule class so that it interrupts, but not sure about what exactly (apparently this is specifically a problem in Python 2. In Python 3 it should happen automatically IIUC.
Moritz
