[GRASS-dev] Weird bug in r.sun: command hangs forever for some day of the year
Pierre Roudier pierre.roudier at gmail.com
Thu Mar 15 15:22:07 PDT 2018
OK, something additional I noticed: I obviously wrapped the calculations
for each day of the year in a script.
Somehow, it seems I can re-process manually a day that was hanging during
the script.
Below is the script I used:
for DAY in $(seq 1 365);
do
    DOY=$(printf "%03d\n" $((DAY)))
    echo "Processing day ${DOY} ..."
    eval `g.findfile element=cell file="glob_rad_${DOY}"`
    if [ ! "$file" ]
    then
        r.sun elev=dem_1k aspect=aspect_1k slope=slope_1k day=$DAY
glob_rad=glob_rad_${DOY}
        sleep 15
    fi
done
On 16 March 2018 at 11:04, Pierre Roudier <pierre.roudier at gmail.com> wrote:
> Hi,
> Just bumped into the weirdest bug in r.sun on GRASS 7.4 as installed from
> the Ubuntu repository.
> I am using r.sun in Mode 2 to compute the daily average global radiation.
> The GRASS location is using EPSG:3031: this is data over the entire
> Antarctica.
> For some specific days, that seem to be in winter, when most of the
> continent doesn't recieve any solar radiation, the command would hang
> forever at 9%:
> For example I had to kill this command:
> [Raster MASK present]
> GRASS 7.4.0 (modis_lst_2015):/media/pierre/1TB_ext4/code > time r.sun
> elev=dem_1k aspect=aspect_1k slope=slope_1k day=159 glob_rad=glob_rad_159
> --o --verbose
> Number of threads <1>
> Mode 2: integrated daily irradiation for a given day of the year
> Using Linke constant: 3.000000
> Using albedo constant: 0.200000
> Using slope map <slope_1k>
> Using aspect map <aspect_1k>
> ^C 9%
> But for the day before and the day after the command was successful in
> less than a minute:
> elev=dem_1k aspect=aspect_1k slope=slope_1k day=160 glob_rad=glob_rad_160
> --o --verbose
>  100%
> real    0m30.019s
> user    0m29.602s
> sys    0m0.372s
> It also happened on day 151... I'm a bit stuck, so any pointers would be
> appreciated.
> Cheers,
> Pierre
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20180316/e8d8546c/attachment.html>
