[GRASS-dev] [GRASS GIS] #2790: Output of t.rast.list with method=comma and columns=name does not differ from output with columns=id
GRASS GIS trac at osgeo.org
Mon Mar 19 15:41:35 PDT 2018
  Reporter:  veroandreo  |      Owner:  grass-dev@…
      Type:  defect      |     Status:  new
  Priority:  normal      |  Milestone:  7.4.1
 Component:  Temporal    |    Version:  svn-trunk
Resolution:              |   Keywords:  t.rast.list, t.vect.list
       CPU:  x86-64      |   Platform:  Linux
Changes (by veroandreo):
 * keywords:  t.rast.list => t.rast.list, t.vect.list
 * milestone:  7.0.7 => 7.4.1
Comment:
 This issue also applies to G7:t.vect.list, i.e., the output of:
 t.vect.list input=bushfires_yearly method=comma columns=id
 and
 t.vect.list input=bushfires_yearly method=comma columns=name
 is exactly the same, while indeed the second command should output only
 the stvds name without the "@mapsename" part.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2790#comment:9>
