[GRASS-dev] [GRASS GIS] #3520: colorize vector layers in GUI by default
GRASS GIS trac at osgeo.org
Tue Mar 20 12:12:22 PDT 2018
  Reporter:  martinl      |      Owner:  grass-dev@…
      Type:  task         |     Status:  new
  Priority:  normal       |  Milestone:  7.6.0
 Component:  wxGUI        |    Version:  unspecified
Resolution:               |   Keywords:  vector, colors
       CPU:  Unspecified  |   Platform:  Unspecified
Comment (by martinl):
 Replying to [comment:4 wenzeslaus]:
 > I agree that the current default is not ideal. Preferred behavior
 probably depends on the use case, but `-c` as default is quite different
 from what everybody else does (so potentially it is unexpected): loading
 each vector layer to map display with different single color versus
 different color for each feature in the vector map/layer. I think it is a
 great checkbox, just not sure if it should be enabled by default.
 You are right, `-c` shouldn't be enabled by default. After some testing I
 can say that it's messy in many cases (point layers for example). I am
 leaving this ticket open in order to implement new GUI settings to
 colorize map layers (not features) similarly as other software do.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3520#comment:5>
