[GRASS-dev] Introduction
Supreet Singh Gill sharrygill5656 at gmail.com
Thu Mar 22 03:14:52 PDT 2018
but it is working for me, I attached the grass_cmd_output and
test_keyvalue_result.
I tested on nc_spm_08_grass7
Thank You
Supreet Singh
https://singhsupreet.github.io/
On Thu, Mar 22, 2018 at 3:32 PM, Luca Delucchi <lucadeluge at gmail.com> wrote:
> On 22 March 2018 at 10:07, Supreet Singh Gill <sharrygill5656 at gmail.com>
> wrote:
> > Hi,
> Hi,
> > I attached the fixed file.
> still not working
> > Thank You
> > Supreet Singh
> ciao
> Luca
> www.lucadelu.org
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20180322/663649f7/attachment.html>
time=0.722s
status=succeeded
total=3
failures=0
errors=0
successes=3
skipped=0
expected_failures=0
unexpected_successes=0
tested_modules=r.mode,r.mode,r.mode
supplementary_files=
test_type=not-specified
cd "Desktop"
Working directory changed to:
"/home/sharry/Desktop"
(Thu Mar 22 15:41:11 2018)
python testrmode.py
GRASS_INFO_PERCENT: 0
GRASS_INFO_PERCENT: 3
GRASS_INFO_PERCENT: 6
GRASS_INFO_PERCENT: 9
GRASS_INFO_PERCENT: 12
GRASS_INFO_PERCENT: 15
GRASS_INFO_PERCENT: 18
GRASS_INFO_PERCENT: 21
GRASS_INFO_PERCENT: 24
GRASS_INFO_PERCENT: 27
GRASS_INFO_PERCENT: 30
GRASS_INFO_PERCENT: 33
GRASS_INFO_PERCENT: 36
GRASS_INFO_PERCENT: 39
GRASS_INFO_PERCENT: 42
GRASS_INFO_PERCENT: 45
GRASS_INFO_PERCENT: 48
GRASS_INFO_PERCENT: 51
GRASS_INFO_PERCENT: 54
GRASS_INFO_PERCENT: 57
GRASS_INFO_PERCENT: 60
GRASS_INFO_PERCENT: 63
GRASS_INFO_PERCENT: 66
GRASS_INFO_PERCENT: 69
GRASS_INFO_PERCENT: 72
GRASS_INFO_PERCENT: 75
GRASS_INFO_PERCENT: 78
GRASS_INFO_PERCENT: 81
GRASS_INFO_PERCENT: 84
GRASS_INFO_PERCENT: 87
GRASS_INFO_PERCENT: 90
GRASS_INFO_PERCENT: 93
GRASS_INFO_PERCENT: 96
GRASS_INFO_PERCENT: 99
GRASS_INFO_PERCENT: 100
Ran 3 tests in 0.722s
OK
(Thu Mar 22 15:41:12 2018) Command finished (1 sec)
Type: text/x-python
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20180322/663649f7/attachment.py>
