[GRASS-dev] d.linegraph: secondary_width parameter defined as integer but default value is a float
Pietro peter.zamb at gmail.com
Fri Mar 23 15:54:14 PDT 2018
Dear dev,
I've noticed that the module d.linegraph define the secondary_width
parameter as follow:
    /* theoretically for other things than points */
    secondary_width_opt = G_define_option();
    secondary_width_opt->key = "secondary_width";
    secondary_width_opt->description = _("Width of point symbol lines");
    secondary_width_opt->type = TYPE_INTEGER;
    secondary_width_opt->required = NO;
    secondary_width_opt->multiple = YES;
    secondary_width_opt->answer = "0.1";
So the parameter type is supposed to be an integer, but the default value
it is a float?
Is it intentional and in case why?
All the best
Pietro
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20180323/165d0bc6/attachment.html>
