[GRASS-dev] Python Unit-test On "r.basins.fill"
Luca Delucchi lucadeluge at gmail.com
Sun Mar 25 03:19:32 PDT 2018
On 25 March 2018 at 06:56, Sunveer Singh <singhsunveer54 at gmail.com> wrote:
> Hi,
Hi Sunveer,
> Done, attached the working file!
yes it is working and it finish but I get several errors (attached to log file).
Some other suggestion:
- rename the copied vector with a different name
- in the copied vector create a new column and use this one to update the values
> Thank You
thanks to you
> Sunveer
> https://sunveersingh.github.io/
ciao
Luca
www.lucadelu.org
