[GRASS-dev] ERROR grass addon v/r.surf.nnbathy using a lat/lon location
Roberto Marzocchi
roberto.marzocchi at gmail.com
Mon Mar 26 05:50:02 PDT 2018
from grass.pygrass.vector import VectorTopo
pnt = VectorTopo(options['input'])
pnt.open(mode='r')
test=pnt.read(1)
if test.is2D==True:
fout.write(parts[0]+' '+parts[1]+' '+parts[3])
else:
fout.write(parts[0]+' '+parts[1]+' '+parts[4])
Maybe not the best code.. but it seem to works..
2018-03-26 12:21 GMT+02:00 Helmut Kudrnovsky <hellik a web.de>:
> >I have no idea of a possible python command.. I will do some >search..
> Have
> you any suggestion?
> Have a look into pygrass
> https://grass.osgeo.org/grass74/manuals/libpython/pygrass_vector.html
> best regards
> Helmut
> Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Dev-f3991897.html
> grass-dev mailing list
> grass-dev a lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/grass-dev
Un allegato HTML รจ stato rimosso...
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20180326/7d4a6f09/attachment.html>
