[GRASS-dev] [GRASS GIS] #3538: add r.clip into core modules
GRASS GIS trac at osgeo.org
Wed Mar 28 09:16:59 PDT 2018
  Reporter:  martinl      |      Owner:  grass-dev@…
      Type:  task         |     Status:  new
  Priority:  normal       |  Milestone:  7.6.0
 Component:  Raster       |    Version:  svn-trunk
Resolution:               |   Keywords:  r.clip
       CPU:  Unspecified  |   Platform:  Unspecified
Comment (by Nikos Alexandris):
 Thank you Veronica.
 While I was trying to shorten the label/description, I missed the point of
 the module. The module extracts a portion of a raster map in to a new map.
 Using either the current region or a vector map (optionally with a where
 clause).
 I would (re-)name it to `r.extract` or reword the label/description of the
 module to read something like: "Clips out portion from the input map based
 on either the extent of the current region or a vector map".
 Just my thoughts, Nikos
Ticket URL: <https://trac.osgeo.org/grass/ticket/3538#comment:2>
