[GRASS-dev] [GRASS GIS] #3538: add r.clip into core modules
GRASS GIS trac at osgeo.org
Wed Mar 28 09:28:48 PDT 2018
  Reporter:  martinl      |      Owner:  grass-dev@…
      Type:  task         |     Status:  new
  Priority:  normal       |  Milestone:  7.6.0
 Component:  Raster       |    Version:  svn-trunk
Resolution:               |   Keywords:  r.clip
       CPU:  Unspecified  |   Platform:  Unspecified
Comment (by martinl):
 Replying to [comment:4 martinl]:
 > Replying to [comment:2 Nikos Alexandris]:
 > > I would (re-)name it to `r.extract` or reword the label/description of
 the module to read something like: "Clips out portion from the input map
 based on either the extent of the current region or a vector map".
 > -1 `r.extract` brings more confusion which is not really necessary.
 `r.clip` does the same as G7:v.clip - clips input raster/vector map based
 on current region or vector map if defined.
 It remembers me issue with G7:v.clip label
 Extracts features of input map which overlay features of clip map.
 something like
 Clips features of input vector map which overlay features of clip map.
 We could also sync modules, modify `r.clip` as below:
 * vector -> clip (required)
 * add -r flag
Ticket URL: <https://trac.osgeo.org/grass/ticket/3538#comment:5>
