[GRASS-dev] GSoC introduction Roberta Fagandini
Veronica Andreo
veroandreo at gmail.com
Sun May 6 12:52:32 PDT 2018
Hey Robi,
I just found this review [0]. It is for Landsat, but maybe some insights
could be also useful for you (?)
Cheers :),
Vero
[0]
https://www.researchgate.net/publication/324975294_Cloud_and_Cloud_Shadow_Detection_for_Landsat_Images_The_Fundamental_Basis_for_Analyzing_Landsat_Time_Series
El jue., 3 may. 2018 a las 22:06, Roberto Marzocchi (<
roberto.marzocchi at gmail.com>) escribió:
> Nice! The last step of the script you have written in python works as you
> expected.
> Now it is important to draw a diagram (or schema ) as a summary for you (you
> have worked a lot in the last few months) and to share it with Moritz and
> Markus.
> After that, test, test and test ;-) for validation/calibration of the
> automatic procedure.
> R
> 2018-05-03 18:48 GMT+02:00 Roberta Fagandini <robifagandini at gmail.com>:
>> 2018-05-03 14:03 GMT+02:00 Moritz Lennert <mlennert at club.worldonline.be>:
>>> Hi Roberta,
>> Hi Moritz and Roberto!
>>> On 25/04/18 18:03, Roberta Fagandini wrote:
>>>> 2018-04-25 16:03 GMT+02:00 Moritz Lennert <mlennert at club.worldonline.be
>>>> <mailto:mlennert at club.worldonline.be>>:
>>>> Looking at your bash scripts, I think the first thing to do during
>>>> this bonding period is, as you planned yourself, to get familiar
>>>> with the writing of GRASS modules in Python. You can have a look at
>>>> existing scripts [1, 2] to get feeling for this works and how to
>>>> structure addon code in order to make it directly installable with
>>>> g.extension.
>>>> You can find the actual function definitions and documentation of
>>>> the GRASS Python scripting library at [3]. The functions in that
>>>> library should be more than enough to translate your scripts into a
>>>> (or several) modules.
>>>> Be aware that GRASS modules create their own GUI. So, unless you
>>>> need some interactive features in your modules, you will not have to
>>>> program your own GUI.
>>>> Thank you for your precious suggestions! I'll start studying how to
>>>> write a GRASS module in Python in the next days and at the same time I will
>>>> keep on testing the procedures so as to show you some results and fix some
>>>> open points.
>>>> Something else you should probably do during this bonding time is to
>>>> elaborate a schema of your algorithm, so that it is easier to
>>>> understand what it does at each step.
>>>> Yes, this could be very useful also for me in order to better organize
>>>> and put in order everything!
>>> Have you advanced on any of this ? Do you have any questions ? Please
>>> don't hesitate to ask on the mailing list.
>> Yes, I started working with GRASS Python scripting library. I'm following
>> the link [0] you suggested, I'm also looking at other existing GRASS
>> scripts [1,2] and moreover, Roberto gave me one of his scripts as an
>> example. I have just committed the first version of the python script I'm
>> working on, it works and I'm quite satisfied ;-)
>> Tomorrow I want to elaborate the schema of the algorithm and at the same
>> time, I have to keep testing the procedure. As I wrote in the bash file,
>> shadows detection seems to be strongly land cover dependent therefore I
>> think it is necessary to test the procedure using several images sensed in
>> different seasons, latitude, etc.
>> Anyway, I'll commit some results tomorrow so as to show you something
>> more concrete!
>>> Best wishes,
>>> Moritz
>> Best regards,
>> Roberta
>> [0] https://grass.osgeo.org/grass75/manuals/libpython/script_intro.html
>> [1] https://trac.osgeo.org/grass/browser/grass/trunk/scripts
>> [2] https://trac.osgeo.org/grass/browser/grass-addons/grass7
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20180506/888fe761/attachment-0001.html>
