[GRASS-dev] GSoC introduction Roberta Fagandini
Markus Neteler neteler at osgeo.org
Wed May 9 09:24:13 PDT 2018
On Wed, May 9, 2018 at 10:58 AM, Moritz Lennert
<mlennert at club.worldonline.be> wrote:
> On 09/05/18 09:41, Roberto Marzocchi wrote:
>> Hi Roberta and Moritz!
>> SCHEMA: Roberta has already written the rules in the schema, but I think
>> you need to open it with a google drive app called diagram.io
>> <http://diagram.io>
> Right, a  lot of hoops to jump through to finally being able to see it, but
> I got there. I'm not much of a user of Google services... ;-)
Alternative: https://www.draw.io/  (we use it a lot, just keep the
resulting XML file yourself or share it yourself)
> But IMHO the schema would be more helpful if it contained the actual rules.
> For example, in the cloud detection procedure, it says "First rule:
> blue-green-red", but this does not provide the actual decision rule. This
> would be helpful to have.
Yes...
Markus
