[GRASS-dev] [GRASS GIS] #3546: t.rast.what: issues in one_point_per_col_output()
GRASS GIS trac at osgeo.org
Wed May 16 00:10:34 PDT 2018
  Reporter:  sbl       |      Owner:  grass-dev@…
      Type:  defect    |     Status:  new
  Priority:  normal    |  Milestone:  7.4.1
 Component:  Temporal  |    Version:  7.4.0
Resolution:            |   Keywords:  t.rast.what
       CPU:  All       |   Platform:  All
Comment (by veroandreo):
 Replying to [comment:7 sbl]:
 > Thanks for testing! If there is agreement on removing coordinates if cat
 is used, I can change that. Not sure if that can go to 7.4, though???
 IMHO, it's a minor change in the behavior of a flag, but I don't think it
 can go into 7.4. I guess into 7.6, no?
 > Please also test attached new diff that fixes the empty column in the
 timerow output and an empty line if header is not requested...
 Just tested the patch, looks exactly as you showed, great :)
Ticket URL: <https://trac.osgeo.org/grass/ticket/3546#comment:8>
