[GRASS-dev] Hardlinking raster map files
Nikos Alexandris nik at nikosalexandris.net
Tue May 22 11:22:14 PDT 2018
Dears,
before creating the HPC related Wiki,
I would like to ask for your advise on hard-linking raster maps files.
Soeren suggested this as a tip, I understand to save time and space.
Hard-linking was also mentioned inside the JEODPP (JRC) team at some point.
I have implemented hard-linking raster maps in https://gitlab.com/NikosAlexandris/r.internal.sh.
It's a shell script, does not compile. Will convert in Python, if useful.
If you hard-link files, how do you perform it?
If of your interest, what do you think about it?
What would be important considerations to pay attention to?
Would you name such a module differently?
Would you consider soft-linking in addition or instead of?
Would you add  a "dry-run" option (as in "don't do anything, just show what you want to do")?
Thank you, Nikos
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20180522/d2cb03e9/attachment.sig>
