[GRASS-dev] [GRASS GIS] #3569: pyGRASS: vector attributes return None
GRASS GIS trac at osgeo.org
Wed May 30 15:21:30 PDT 2018
 Reporter:  lucadelu                      |      Owner:  grass-dev@…
     Type:  defect                        |     Status:  new
 Priority:  normal                        |  Milestone:  7.4.2
Component:  PyGRASS                       |    Version:  unspecified
 Keywords:  VectorTopo, attributes table  |        CPU:  All
 Platform:  All                           |
 If you try to open a vector map in a Mapset different from the current it
 seems not possible to read attributes. Running the following code from
 user1 mapset of nc_spm_08
 #counties = VectorTopo('boundary_county')
 counties = VectorTopo('boundary_county', mapset='PERMANENT')
 counties.open('r')
 first = counties[1]
 first
 first.attrs.values()
Ticket URL: <https://trac.osgeo.org/grass/ticket/3569>
