[GRASS-dev] Problem starting GRASS GUI - ntpath splitdrive
Pedro Venâncio pedrongvenancio at gmail.com
Mon Nov 5 09:28:59 PST 2018
Hi Martin,
I did not have this environment variable set, but I set it and it still
does not work.
Anyway, I don't remember the last time I used GRASS GUI on this machine,
but it was about 2 weeks ago.
Then this problem must have resulted from a recent change / update.
Thanks Martin.
Best regards,
Pedro
Martin Landa <landa.martin  gmail.com> escreveu no dia segunda, 5/11/2018
à(s) 16:40:
> Hi,
> po 5. 11. 2018 v 17:36 odesílatel Pedro Venâncio
> <pedrongvenancio  gmail.com> napsal:
> >     os.getenv('HOMEPATH'))
> >   File "C:\OSGEO4~1\apps\Python27\lib\ntpath.py", line 65, in join
> >     result_drive, result_path = splitdrive(path)
> >   File "C:\OSGEO4~1\apps\Python27\lib\ntpath.py", line 115, in splitdrive
> >     if len(p) > 1:
> > TypeError: object of type 'NoneType' has no len()
> it seems that HOMEPATH environmental variable is not defined for your
> account.
> > I'm using Windows 10.
> Based on [1] HOMEPATH should be defined on Windows 10 too.
> Haven't you unset HOMEPATH for your account by chance? Try to set
> HOMEPATH pointing to your home directory.
> Martin
> [1]
> https://www.tenforums.com/tutorials/3234-environment-variables-windows-10-a.html
> Martin Landa
> http://geo.fsv.cvut.cz/gwiki/Landa
> http://gismentors.cz/mentors/landa
-------------- próxima parte ----------
Um anexo em HTML foi limpo...
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20181105/d2be9330/attachment-0001.html>
