[GRASS-dev] Problem starting GRASS GUI - ntpath splitdrive
Pedro Venâncio pedrongvenancio at gmail.com
Tue Nov 6 12:11:50 PST 2018
Hi Helmut,
Helmut Kudrnovsky <hellik  web.de> escreveu no dia terça, 6/11/2018 à(s)
19:24:
> >C:\>grass74
> >Cleaning up temporary files...
> >Starting GRASS GIS...
> >ERROR: Invalid return code from GUI startup script.
> >Please advise GRASS developers of this error.
> >Exiting...
> >Press any key to continue . . .
> what is the invalid return code?
The error falls here, like Markus said:
def gui_startup(grass_gui):
    """Start GUI for startup (setting gisrc file)"""
    if grass_gui in ('wxpython', 'gtext'):
        ret = call([os.getenv('GRASS_PYTHON'), wxpath("gis_set.py")])
    # this if could be simplified to three branches (0, 5, rest)
    # if there is no need to handle unknown code separately
    if ret == 0:
        pass
    elif ret in [1, 2]:
        # 1 probably error coming from gis_set.py
        # 2 probably file not found from python interpreter
        # formerly we were starting in text mode instead, now we just fail
        # which is more straightforward for everybody
        fatal(_("Error in GUI startup. See messages above (if any)"
                " and if necessary, please"
                " report this error to the GRASS developers.\n"
                "On systems with package manager, make sure you have the
right"
                " GUI package, probably named grass-gui, installed.\n"
                "To run GRASS GIS in text mode use the -text flag.\n"
                "Use '--help' for further options\n"
                "     {cmd_name} --help\n"
                "See also:
https://grass.osgeo.org/{cmd_name}/manuals/helptext.html").format(
                    cmd_name=cmd_name))
    elif ret == 5:  # defined in gui/wxpython/gis_set.py
        # User wants to exit from GRASS
        message(_("Exit was requested in GUI.\nGRASS GIS will not start.
Bye."))
        sys.exit(0)
    else:
        fatal(_("Invalid return code from GUI startup script.\n"
                "Please advise GRASS developers of this error."))
> is there another python installation on this windows system?
Yes, I've Python 2.7 and Python 3.7, both instaled with OSGeo4W, one for
QGIS 2.18 and another for QGIS 3.4. But I've the same on another machine.
> >The strange thing is that both systems are similar, and it works in one,
> and not in another.
> can you delete all the content in:
> C:\Users\YourUserName\AppData\Roaming\GRASS7
> and try to restart
I already tested this, but after delete it, it only create an empty GRASS7
folder.
> what is happening when you're in text mode and do
> C:\>g.gui wxpython
C:\>g.gui wxpython
Launching <wxpython> GUI in the background, please wait...
C:\>
but it does not launch the GUI. Looking at the windows task manager
processes, the GRASS GUI process shows up, but closes right after a second
or so.
Thank you very much for the help Helmut and Markus!
Best regards,
Pedro
-------------- próxima parte ----------
Um anexo em HTML foi limpo...
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20181106/7bc4b392/attachment.html>
