[GRASS-dev] PyGRASS: changing description and comments
Luca Delucchi lucadeluge at gmail.com
Tue Nov 13 00:03:24 PST 2018
Il giorno sab 10 nov 2018, 17:46 Luí­s Moreira de Sousa <
luis.de.sousa at protonmail.ch> ha scritto:
> Hi all,
Hi Luis,
> is there a way of modifying the contents of the description and comments
> fields associated with rasters? I could also use r.support, but it would be
> more elegant to use the API.
It seems that description and comments are not possible to be modified by
the API, other values instead are [0]
[0]
https://grass.osgeo.org/grass70/manuals/libpython/pygrass.raster.html#module-pygrass.raster.history
> Thank you.
Ciao
Luca
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20181113/8ba851ad/attachment-0001.html>
