[GRASS-dev] [GRASS GIS] #3693: Issue with G76 in docker: creating a location fails
GRASS GIS trac at osgeo.org
Tue Nov 13 01:58:22 PST 2018
  Reporter:  neteler  |      Owner:  grass-dev@…
      Type:  defect   |     Status:  new
  Priority:  normal   |  Milestone:  7.4.3
 Component:  Startup  |    Version:  svn-releasebranch76
Resolution:           |   Keywords:  docker g.proj
       CPU:  x86-64   |   Platform:  Linux
Comment (by neteler):
 Problem solved: update of docker-compose from v1.8.0 to v1.23.1 (what a
 waste of time to figure out this one...).
 Explanations:
 Program received signal SIGILL, Illegal instruction.
 This means that a CPU instruction is called which is not present in the
 CPU running the docker. In our case, we run it on a KVM virtualization.
 Apparently docker-compose v1.23 (at least, later than v1.8 addresses the
 problem of the missing instruction). w00t!
 Closing.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3693#comment:5>
