[GRASS-dev] [GRASS-user] r.covar vs layerStats in R
Markus Metz markus.metz.giswork at gmail.com
Tue Nov 20 12:05:01 PST 2018
On Tue, Nov 20, 2018 at 7:59 PM Micha Silver <tsvibar at gmail.com> wrote:
> On 11/19/18 12:41 PM, Markus Neteler wrote:
> > On Sun, Nov 18, 2018 at 10:32 PM Micha Silver <tsvibar at gmail.com> wrote:
> >> I am preparing a correlation matrix for 7 raster layers. The results
using the r.covar module are different from the R layerStats function. I
suspect this is due to handling of null cells. The R function has a
parameter to remove NA cells, but the GRASS module, I think, just loops
over all cells, including no value.
> >> Can anyone confirm that GRASS does not deal with null cells, and that
this would cause the difference in correlation results?
> > Here how r.covar treats NULL cells:
https://trac.osgeo.org/grass/browser/grass/trunk/raster/r.covar/main.c#L93
> Looking at lines 94 - 100, it seems that the count variable is
> incremented even when a cell value is null.
because of the "continue;", count is not incremented if any cell value is
null
Markus M
> Please correct me if I'm wrong.
> Since count is used in the calculation of covariance and correlation
> (lines 118-132) shouldn't it contain the number only of cells with value?
> Thanks
> > Markus
> Micha Silver
> Ben Gurion Univ.
> Sde Boker, Remote Sensing Lab
> cell: +972-523-665918
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20181120/a964050c/attachment.html>
