[GRASS-dev] OSGeo4W-winGRASS 7.7 with new gdal, geos, proj4
Martin Landa landa.martin at gmail.com
Thu Oct 18 05:16:03 PDT 2018
čt 18. 10. 2018 v 13:59 odesílatel Martin Landa <landa.martin at gmail.com> napsal:
> > As long as the old PROJ 4 API is still supported by PROJ 5, G74 can use PROJ 5, no need to disable G74 or downgrade PROJ. G74 would simply not make use of new features and the new API in PROJ5.
> ah, you are right. Martin
building/packaging environment updated, let's check tomorrow the next
G74 build. I just wonder about GRASS modules which uses PROJ command
lines. They can be affected of PROJ4 -> PROJ5 switch. Are we aware of
that?
Thanks, Ma
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
