[GRASS-dev] OSGeo4W-winGRASS - for anyone working?
Veronica Andreo veroandreo at gmail.com
Thu Oct 18 12:30:51 PDT 2018
oh my!
I'll teach a one week course to windows users next week and I strongly
recommend students to install GRASS through OSGeo4W because it is the
easiest way to use bash tricks... I'm kinda panicking with this email, I
tested 3 weeks ago or so and all worked just fine...
El jue., 18 oct. 2018 a las 21:11, Helmut Kudrnovsky (<hellik at web.de>)
escribió:
> there were quite a lot changes lately in the OSGeo4W environment.
> trying to start the long installed GRASS 7.4.1
> C:\>Traceback (most recent call last):
>   File "C:\OSGEO4~1\apps\grass\grass-7.4.1\gui\wxpython\wxgui.py", line
> 167,
> in <module>
>     sys.exit(main())
> 154,
> in main
>     app = GMApp(workspaceFile)
>   File "C:\OSGEO4~1\apps\grass\grass-7.4.1\gui\wxpython\wxgui.py", line 48,
> in __init__
>     wx.App.__init__(self, False)
>   File
> "C:\OSGEO4~1\apps\Python27\lib\site-packages\wx-2.8-msw-unicode\wx\_core.py",
> line 7981, in __init__
>     self._BootstrapApp()
>   File
> line 7555, in _BootstrapApp
>     return _core_.PyApp__BootstrapApp(*args, **kwargs)
>   File "C:\OSGEO4~1\apps\grass\grass-7.4.1\gui\wxpython\wxgui.py", line 99,
> in OnInit
>     from lmgr.frame import GMFrame
>   File "C:\OSGEO4~1\apps\grass\grass-7.4.1\gui\wxpython\lmgr\frame.py",
> line
> 50, in <module>
>     from lmgr.layertree import LayerTree, LMIcons
>   File "C:\OSGEO4~1\apps\grass\grass-7.4.1\gui\wxpython\lmgr\layertree.py",
> line 38, in <module>
>     from mapdisp.frame import MapFrame
>   File "C:\OSGEO4~1\apps\grass\grass-7.4.1\gui\wxpython\mapdisp\frame.py",
> line 33, in <module>
>     from mapdisp.toolbars import MapToolbar, NvizIcons
>   File
> "C:\OSGEO4~1\apps\grass\grass-7.4.1\gui\wxpython\mapdisp\toolbars.py", line
> 22, in <module>
>     from nviz.main import haveNviz
>   File "C:\OSGEO4~1\apps\grass\grass-7.4.1\gui\wxpython\nviz\main.py", line
> 24, in <module>
>     from nviz import mapwindow
>   File "C:\OSGEO4~1\apps\grass\grass-7.4.1\gui\wxpython\nviz\mapwindow.py",
> line 42, in <module>
>     from nviz.workspace import NvizSettings
>   File "C:\OSGEO4~1\apps\grass\grass-7.4.1\gui\wxpython\nviz\workspace.py",
> line 23, in <module>
>     from nviz import wxnviz
>   File "C:\OSGEO4~1\apps\grass\grass-7.4.1\gui\wxpython\nviz\wxnviz.py",
> line 45, in <module>
>     from grass.lib.raster3d import *
>   File
> "C:\OSGEO4~1\apps\grass\grass-7.4.1\etc\python\grass\lib\raster3d.py", line
> 23, in <module>
>     _libs["grass_g3d.7.4.1"] = load_library("grass_g3d.7.4.1")
>   File
> "C:\OSGEO4~1\apps\grass\grass-7.4.1\etc\python\grass\lib\ctypes_loader.py",
> line 62, in load_library
>     return self.load(path)
>   File
> line 240, in load
>     return _WindowsLibrary(path)
>   File
> line 223, in __init__
>     self.cdll = ctypes.cdll.LoadLibrary(path)
>   File "C:\OSGEO4~1\apps\Python27\lib\ctypes\__init__.py", line 444, in
> LoadLibrary
>     return self._dlltype(name)
>   File "C:\OSGEO4~1\apps\Python27\lib\ctypes\__init__.py", line 366, in
> __init__
>     self._handle = _dlopen(self._name, mode)
> WindowsError: [Error 193] %1 ist keine zulõssige Win32-Anwendung
> starting GRASS 7.7.svn
> C:\>wxnviz.py: [Error 193] %1 ist keine zulõssige Win32-Anwendung
> wxdigit.py: [Error 193] %1 ist keine zulõssige Win32-Anwendung
>   File "C:\OSGEO4~1\apps\grass\grass-7.7.svn\gui\wxpython\wxgui.py", line
> 169, in <module>
>     sys.exit(main())
> 156, in main
> 50, in __init__
>   File
>   File
> 103, in OnInit
>     workspace=self.workspaceFile)
>   File "C:\OSGEO4~1\apps\grass\grass-7.7.svn\gui\wxpython\lmgr\frame.py",
> line 143, in __init__
>     self.notebook = self._createNoteBook()
> line 338, in _createNoteBook
>     gcstyle=GC_PROMPT)
>   File
> "C:\OSGEO4~1\apps\grass\grass-7.7.svn\gui\wxpython\gui_core\goutput.py",
> line 119, in __init__
>     self.cmdPrompt = GPromptSTC(parent=self, menuModel=self._menuModel)
>   File
> "C:\OSGEO4~1\apps\grass\grass-7.7.svn\gui\wxpython\gui_core\prompt.py",
> line
> 139, in __init__
>     GPrompt.__init__(self, parent=parent, menuModel=menuModel)
>   File
> line
> 57, in __init__
>     self.mapList = self._getListOfMaps()
>   File
> line
> 101, in _getListOfMaps
>     result['raster'] = grass.list_strings('raster')
>   File
> "C:\OSGEO4~1\apps\grass\grass-7.7.svn\etc\python\grass\script\core.py",
> line
> 1296, in list_strings
>     mapset=mapset).splitlines():
>   File
> line
> 511, in read_command
>     return handle_errors(returncode, stdout, args, kwargs)
>   File
> line
> 351, in handle_errors
>     returncode=returncode)
> grass.exceptions.CalledModuleError: Module run None g.list--q-mtype=raster
> ended with error
> Process ended with non-zero return code -1073741701. See errors in the
> (error) output.
> C:\>g.version -g
> version=7.7.svn
> date=2018
> revision=r73564
> build_date=2018-10-17
> build_platform=x86_64-w64-mingw32
> build_off_t_size=8
> any idea?
> best regards
> Helmut
> Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Dev-f3991897.html
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20181018/0c61b002/attachment.html>
