[GRASS-dev] [GRASS-user] experimental Python 3 support in trunk
Markus Metz markus.metz.giswork at gmail.com
Wed Sep 5 12:37:44 PDT 2018
On Mon, Sep 3, 2018 at 8:28 AM Markus Neteler <neteler at osgeo.org> wrote:
> Could you please post a few lines how to properly do the testing with
> virtualenv?
If python3 with all required packages is already installed on the system,
there is a simpler solution than virtualenv:
mkdir ~/bin_p3
ln -s /usr/bin/python3 ~/bin_p3/python
# make python3 the default python interpreter
export PATH="~/bin_p3:$PATH"
compile GRASS and run GRASS with these PATH settings
alternatively, the shebang in GRASS *.py files can be changed to python3
(should be changed to python3 according to Python developer's Guide PEP394)
Markus M
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20180905/6448f1be/attachment.html>
