[GRASS-dev] [GRASS GIS] #3593: Error in v.stream.order add-on, segmentation fault
GRASS GIS trac at osgeo.org
Fri Sep 14 10:00:47 PDT 2018
  Reporter:  jradinger    |      Owner:  grass-dev@…
      Type:  defect       |     Status:  new
  Priority:  normal       |  Milestone:
 Component:  Addons       |    Version:  svn-releasebranch74
Resolution:               |   Keywords:
       CPU:  Unspecified  |   Platform:  Unspecified
Comment (by neteler):
 Replying to [comment:3 jradinger]:
 > How can I find out that step/line? Do I need to run the script manually
 or can that be obtained by a specific debug level?
 The easiest way is to use pdb, see
 https://grasswiki.osgeo.org/wiki/GRASS_Debugging#Python_debugging_with_pdb
Ticket URL: <https://trac.osgeo.org/grass/ticket/3593#comment:4>
