[GRASS-dev] r.in.wms: decode() is not defined
Anna Petrášová kratochanna at gmail.com
Wed Sep 19 10:38:06 PDT 2018
ok, try this diff and let me know if there are more problems
Index: scripts/r.in.wms/wms_drv.py
--- scripts/r.in.wms/wms_drv.py (revision 73363)
+++ scripts/r.in.wms/wms_drv.py (working copy)
@@ -229,7 +229,7 @@
                                         flags='wf',
                                         epsg=self.params['srs'])
         projection = projection.rstrip('\n')
-        temp_map_dataset.SetProjection(projection)
+        temp_map_dataset.SetProjection(grass.encode(projection))
         pixel_x_length = (map_region['maxx'] - map_region['minx']) /
int(map_region['cols'])
         pixel_y_length = (map_region['miny'] - map_region['maxy']) /
int(map_region['rows'])
On Wed, Sep 19, 2018 at 11:40 AM Veronica Andreo <veroandreo at gmail.com>
wrote:
> Now I get a different one:
> Traceback (most recent call last):
>   File
> "/home/veroandreo/software/grass7_trunk/dist.x86_64-pc-linux-gnu/gui/scripts/d.wms",
> line 214, in <module>
>     sys.exit(main())
>   File
> line 207, in main
>     temp_map = wms.GetMap(options, flags)
>   File
> "/home/veroandreo/software/grass7_trunk/dist.x86_64-pc-linux-gnu/etc/r.in.wms/wms_base.py",
> line 215, in GetMap
>     self.temp_map = self._download()
>   File
> "/home/veroandreo/software/grass7_trunk/dist.x86_64-pc-linux-gnu/etc/r.in.wms/wms_drv.py",
> line 232, in _download
>   File "/usr/lib64/python2.7/site-packages/osgeo/gdal.py", line 1851, in
> SetProjection
>     return _gdal.Dataset_SetProjection(self, *args)
> TypeError: in method 'Dataset_SetProjection', argument 2 of type 'char
> const *'
> GRASS_INFO_END(3660,1)
> ERROR 4:
> /home/veroandreo/grassdata/latlong_wgs84/pruebas/.tmp/localhost.localdomain/3210.4:
> No such file or directory
> ERROR 4:
> using r73371
> Vero
> El mié., 19 sept. 2018 a las 15:27, Anna Petrášová (<kratochanna at gmail.com>)
> escribió:
>> Try r73369.
>> On Wed, Sep 19, 2018 at 8:17 AM Veronica Andreo <veroandreo at gmail.com>
>> wrote:
>>> I use the module from the GUI and I get the same error as Yann in the
>>> terminal, plus:
>>> GRASS_INFO_END(28730,1)
>>> ERROR 4:
>>> /home/veroandreo/grassdata/nc_spm_08_grass7/user1/.tmp/localhost.localdomain/28556.4:
>>> ERROR 4:
>>> Vero
>>> El mié., 19 sept. 2018 a las 8:50, Yann Chemin (<
>>> dr.yann.chemin at gmail.com>) escribió:
>>>> Hi
>>>> maybe I am missing a library?
>>>> /usr/local/grass-7.7.svn/scripts/r.in.wms url=url="
>>>> https://tiles.maps.eox.at/wms?" output=sen2cloudless layers=s2cloudless
>>>>   File "/usr/local/grass-7.7.svn/scripts/r.in.wms", line
>>>> 241, in <module>
>>>>     sys.exit(main())
>>>> 227, in main
>>>>     fetched_map = wms.GetMap(options, flags)
>>>>   File "/usr/local/grass-7.7.svn/etc/r.in.wms/wms_base.py",
>>>> line 212, in GetMap
>>>>     self._initializeParameters(options, flags)
>>>> line 137, in _initializeParameters
>>>>     self.proj_srs = decode(self.proj_srs).rstrip('\n')
>>>> NameError: global name 'decode' is not defined
>>>> Dr. Yann Chemin
>>>> Freelancer
>>>> +33 7 83 85 5234
>>>> 3 Toulmelin, 56400 Plumergat, FR
>>>> https://www.paypal.me/yannchemin
>>>> _______________________________________________
>>>> grass-dev mailing list
>>>> grass-dev at lists.osgeo.org
>>>> https://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20180919/37354a6f/attachment.html>
