[GRASS-dev] [GRASS GIS] #3822: Tests for r.basins.fill are broken
GRASS GIS trac at osgeo.org
Sat Apr 20 14:46:02 PDT 2019
  Reporter:  pmav99       |      Owner:  grass-dev@…
      Type:  defect       |     Status:  new
  Priority:  normal       |  Milestone:
 Component:  Tests        |    Version:  svn-trunk
Resolution:               |   Keywords:
       CPU:  Unspecified  |   Platform:  Unspecified
Comment (by mmetz):
 Replying to [comment:1 neteler]:
 > After renaming the maps (see attached patch) the test passes here.
 Does it make sense to adjust tests to a test mapset that is 1) not
 available, 2) in alpha state?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3822#comment:2>
