[GRASS-dev] [GRASS GIS] #3227: g.gui.rlisetup: possibility to execute in command line ?
    trac at osgeo.org
    Mon Apr 29 08:32:28 PDT 2019
  Reporter:  tgrippa      |      Owner:  grass-dev@…
      Type:  enhancement  |     Status:  new
  Priority:  normal       |  Milestone:  7.0.7
 Component:  Raster       |    Version:  unspecified
Resolution:               |   Keywords:
       CPU:  Unspecified  |   Platform:  All
Comment (by tgrippa):
 Here is the function. It allows to create setup file for landscape
 polygons. If there are several base rasters (the categorical raster on
 which to compute landscape metrics using r.li), it allows for the creation
 of multiple setup file.
 I'm sure this function could be improved but at least has the merit of
 existing ;)
 ##### Function that create the r.li configuration file for a list of
 landcover raster.
 ### It enable to create in one function as many configuration file as the
 number of raster provided in 'listoflandcoverraster'.
 ### It could be use only in case study with a several landcover raster and
 only one landscape unit layer.
 ### So, the landscape unit layer if fixed and there are the landcover
 raster which change.
 # 'listoflandcoverraster' wait for a list with the name (string) of
 landcover rasters.
 # 'landscape_polygons' wait for the name (string) of the vector layer
 containing the polygons to be used as landscape units.
 # 'masklayerhardcopy' wait for a boolean value (True/False) depending if
 the user want to create hard copy of the landscape units mask layers or
 not.
 # 'returnlistpath' wait for a boolean value (True/False) according to the
 fact that a list containing the path to the configuration files is
 desired.
 # 'ncores' wait for a integer corresponding to the number of desired cores
 to be used for parallelization.
 # Import GRASS lib
 import grass.script as gscript
 # Import libraries for multiprocessing
 import multiprocessing
 from multiprocessing import Pool
 from functools import partial
 # Function that copy the landscape unit raster masks on a new layer with
 name corresponding to the current 'landcover_raster'
 def
 copy_landscapeunitmasks(current_landcover_raster,base_landcover_raster,landscape_polygons,landscapeunit_bbox,cat):
     ### Copy the landscape units mask for the current 'cat'
     # Define the name of the current "current_landscapeunit_rast" layer
 current_landscapeunit_rast=current_landcover_raster.split("@")[0]+"_"+landscape_polygons.split("@")[0]+"_"+str(cat)
 base_landscapeunit_rast=base_landcover_raster.split("@")[0]+"_"+landscape_polygons.split("@")[0]+"_"+str(cat)
     # Copy the the landscape unit created for the first landcover map in
 order to match the name of the current landcover map
     gscript.run_command('g.copy', overwrite=True, quiet=True,
 raster=(base_landscapeunit_rast,current_landscapeunit_rast))
     # Add the line to the text variable
     text="MASKEDOVERLAYAREA
 "+current_landscapeunit_rast+"|"+landscapeunit_bbox[cat]
     return text
 # Function that create the r.li configuration file for the base landcover
 raster and then for all the binary rasters
 def create_rli_configfile(listoflandcoverraster,landscape_polygons,
 masklayerhardcopy=False,returnlistpath=True,ncores=2):
     # Check if 'listoflandcoverraster' is not empty
     if len(listoflandcoverraster)==0:
         sys.exit("The list of landcover raster is empty and should contain
 at least one raster name")
     # Check if rasters provided in 'listoflandcoverraster' exists to avoid
 error in mutliprocessing
     for cur_rast in listoflandcoverraster:
         try:
             mpset=cur_rast.split("@")[1]
         except:
             mpset=""
         if cur_rast.split("@")[0] not in [x[0] for x in
 gscript.list_pairs(type='raster',mapset=mpset)]:
             sys.exit('Raster <%s> not found' %cur_rast)
     # Check if rasters provided in 'listoflandcoverraster' have the same
 extend and spatial resolution
     raster={}
     for x, rast in enumerate(raster_list):
         raster[x]=gscript.raster_info(rast)
     key_list=raster.keys()
     for x in key_list[1:]:
         for info in ('north','south','east','west','ewres','nsres'):
             if not raster[0][info]==raster[x][info]:
                 sys.exit("Some raster provided in the list have different
 spatial resolution or extend, please check")
     # Get the version of GRASS GIS
     version=grass.version()['version'].split('.')[0]
     # Define the folder to save the r.li configuration files
     if sys.platform=="win32":
         rli_dir=os.path.join(os.environ['APPDATA'],"GRASS"+version,"r.li")
     else:
         rli_dir=os.path.join(os.environ['HOME'],".grass"+version,"r.li")
     if not os.path.exists(rli_dir):
         os.makedirs(rli_dir)
     ## Create an ordered list with the 'cat' value of landscape units to
 be processed.
     list_cat=[int(x) for x in gscript.parse_command('v.db.select',
 quiet=True,
 map=landscape_polygons, column='cat', flags='c')]
     list_cat.sort()
     # Declare a empty dictionnary which will contains the north, south,
 east, west values for each landscape unit
     landscapeunit_bbox={}
     # Declare a empty list which will contain the path of the configation
 files created
     listpath=[]
     # Declare a empty string variable which will contains the core part of
     maskedoverlayarea_1=""
     # Duplicate 'listoflandcoverraster' in a new variable called
 'tmp_list'
     tmp_list=list(listoflandcoverraster)
     # Set the current landcover raster as the first of the list
     base_landcover_raster=tmp_list.pop(0) #The pop function return the
 first item of the list and delete it from the list at the same time
     # Loop trough the landscape units
     for cat in list_cat:
         # Extract the current landscape unit polygon as temporary vector
 tmp_vect="tmp_"+base_landcover_raster.split("@")[0]+"_"+landscape_polygons.split("@")[0]+"_"+str(cat)
         gscript.run_command('v.extract', overwrite=True, quiet=True,
                             input=landscape_polygons, cats=cat,
 output=tmp_vect)
         # Set region to match the extent of the current landscape polygon,
 with resolution and alignement matching the landcover raster
         gscript.run_command('g.region', vector=tmp_vect,
 align=base_landcover_raster)
         # Rasterize the landscape unit polygon
         landscapeunit_rast=tmp_vect[4:]
         gscript.run_command('v.to.rast', overwrite=True, quiet=True,
 input=tmp_vect, output=landscapeunit_rast, use='cat', memory='3000')
         # Remove temporary vector
         gscript.run_command('g.remove', quiet=True, flags="f",
 type='vector', name=tmp_vect)
         # Set the region to match the raster landscape unit extent and
 save the region info in a dictionary
         region_info=gscript.parse_command('g.region',
 raster=landscapeunit_rast, flags='g')
         n=str(round(float(region_info['n']),5)) #the config file need 5
 decimal for north and south
         s=str(round(float(region_info['s']),5))
         e=str(round(float(region_info['e']),6)) #the config file need 6
 decimal for east and west
         w=str(round(float(region_info['w']),6))
         # Save the coordinates of the bbox in the dictionary (n,s,e,w)
         landscapeunit_bbox[cat]=n+"|"+s+"|"+e+"|"+w
         # Add the line to the maskedoverlayarea_1 variable
         maskedoverlayarea_1+="MASKEDOVERLAYAREA
 "+landscapeunit_rast+"|"+landscapeunit_bbox[cat]+"\n"
     # Compile the content of the r.li configuration file
     config_file_content="SAMPLINGFRAME 0|0|1|1\n"
     config_file_content+=maskedoverlayarea_1
     config_file_content+="RASTERMAP "+base_landcover_raster+"\n"
     config_file_content+="VECTORMAP "+landscape_polygons+"\n"
     # Create a new file and save the content
 configfilename=base_landcover_raster.split("@")[0]+"_"+landscape_polygons.split("@")[0]
     path=os.path.join(rli_dir,configfilename)
     listpath.append(path)
     f=open(path, 'w')
     f.write(config_file_content)
     f.close()
     # Continue creation of r.li configuration file and landscape unit
 raster the rest of the landcover raster provided
     while len(tmp_list)>0:
         # Initialize 'maskedoverlayarea_2' variable as an empty string
         maskedoverlayarea_2=""
         current_landcover_raster=tmp_list.pop(0) #The pop function return
 the first item of the list and delete it from the list at the same time
         if masklayerhardcopy: # If the user asked for hard copy of the
             # Copy all the landscape units masks for the current landcover
 raster
             p=Pool(ncores) #Create a pool of processes and launch them
 using 'map' function
 func=partial(copy_landscapeunitmasks,current_landcover_raster,base_landcover_raster,landscape_polygons,landscapeunit_bbox)
 # Set fixed argument of the function
             maskedoverlayarea_2=p.map(func,list_cat) # Launch the
 processes for as many items in the list and get the ordered results using
 map function
             p.close()
             p.join()
             config_file_content+="\n".join(maskedoverlayarea_2)+"\n"
 "+current_landcover_raster+"\n"
         else: # If the user not asked for hard copy
             config_file_content+=maskedoverlayarea_1  # If user do not
 asked for hard copy, the mask layers are the same than for the first
 configuration file
 "+current_landcover_raster+"\n"  # But the name of the RASTERMAP should be
 the one of the current landcover raster
 configfilename=current_landcover_raster.split("@")[0]+"_"+landscape_polygons.split("@")[0]
         f=open(path, 'w')
         f.close()
     # Return a list of path of configuration files creates if option
 actived
     if returnlistpath:
         return list_cat,listpath
     else:
         return list_cat
Ticket URL: <https://trac.osgeo.org/grass/ticket/3227#comment:7>
