[GRASS-dev] Docker image based on Alpine Linux with GRASS GIS 7.7.git and wxGUI
Vaclav Petras wenzeslaus at gmail.com
Thu Aug 1 12:25:40 PDT 2019
On Thu, Aug 1, 2019 at 1:22 PM Markus Neteler <neteler at osgeo.org> wrote:
> Hi,
> On Thu, Aug 1, 2019 at 1:59 AM Vaclav Petras <wenzeslaus at gmail.com> wrote:
> > On Wed, Jul 31, 2019 at 11:41 AM Markus Neteler <neteler at osgeo.org>
> wrote:
> >> In fact, $GISBASE/gui/wxpython/wxgui.py isn't present in the docker
> image.
> >> Do you have an idea what to look for (say, what does it (not) generate)?
> > Hi Markus, wxgui.py is a file copied from source to distribution by
> make, so the question is what compilation output says.
> https://cloud.docker.com/repository/registry-1.docker.io/neteler/docker-alpine-grass-gis-gui/builds/c8c39f18-33cb-44df-a669-23f8cdc5682f
The link does not work for me. Do I have to create an account?
> /usr/bin/install -c -m 644 wxgui.py
> /src/grass_build/dist.x86_64-pc-linux-gnu/gui/wxpython/wxgui.py
This says /src/grass_build/dist.x86_64-pc-linux-gnu/. I assume it is from
"make" but the GRASS GIS there is running from /usr/local/grass77, so I
assume there is also the "make install" step?
I did:
$ docker run -i -t --rm -v $(pwd):/tmp -v /tmp/.X11-unix:/tmp/.X11-unix -e
uid=$(id -u) -e gid=$(id -g) -e DISPLAY=unix$DISPLAY --name grass77
neteler/docker-alpine-grass-gis-gui grass77 --tmp-location XY --exec bash
$ ls /src
$ echo $GISBASE
/usr/local/grass77
$ ls $GISBASE/gui
ls: /usr/local/grass77/gui: No such file or directory
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20190801/3f228fcb/attachment.html>
