[GRASS-dev] Try GRASS GIS online: Binder - mybinder.org
Vaclav Petras wenzeslaus at gmail.com
Wed Aug 7 21:27:24 PDT 2019
Dear all,
I would like GRASS GIS to have a page similar to these:
https://jupyter.org/try
"You can try Jupyter out right now, without installing anything."
https://learngitbranching.js.org/
Learn by doing: Try Git commands right from your web browser. (
http://try.github.io/)
https://training.play-with-docker.com/ops-s1-hello/
Play with Docker classroom
It seems that Binder might be the way for all command line and Python
related things (and more). I started with couple of notebooks (click the
"launch binder" button at the beginning of each readme file):
https://github.com/wenzeslaus/try-grass-in-jupyter
https://github.com/wenzeslaus/try-grass-in-jupyter-with-bash
https://github.com/wenzeslaus/grass-zonal-of-solar
First is a basic Python with starting a GRASS GIS session with outputs
saved already (computed notebook). Second is a running GRASS GIS session
and Bash without outputs (you need to run it to see any images). Third is
like the first, but instead of a basic usage, it is a more elaborate
workflow adding Matplotlib (it is unfinished, it should be more than one
notebook).
About Binder (mybinder.org): Basically it makes Jupyter Notebooks from Git
come alive through Docker. This can be also reproduced on any other server.
Binder is a service by Project Jupyter. Binder can do more than just Python
(or Bash) notebooks most notably JupyterLab, RStudio, and C/C++.
https://mybinder.readthedocs.io/en/latest/about.html
There is much more to be discussed. Let me know what you think about this
and about what should be done before promoting this on the website.
Best,
Vaclav
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20190808/beeae22f/attachment.html>
