[GRASS-dev] Try GRASS GIS online: CoCalc - cocalc.com
Stefan Blumentrath Stefan.Blumentrath at nina.no
Fri Aug 16 02:14:29 PDT 2019
BTW, now also the GUI is installed.
They replied very quickly to my request… And the size of CoCal is likely due to their apparent concept of offering “everything” by default…
Cheers
Stefan
Sent: torsdag 8. august 2019 15:57
To: grass-dev at lists.osgeo.org
Cc: Yann Chemin <dr.yann.chemin at gmail.com>; Stefan Blumentrath <Stefan.Blumentrath at nina.no>
Subject: Try GRASS GIS online: CoCalc - cocalc.com
[was: Re: [GRASS-dev] Try GRASS GIS online: Binder - mybinder.org<http://mybinder.org>]
On Thu, Aug 8, 2019 at 6:22 AM Stefan Blumentrath <Stefan.Blumentrath at nina.no<mailto:Stefan.Blumentrath at nina.no>> wrote:
For courses also: https://cocalc.com/
could be interesting. It does not (yet?) ship GRASS by default though.
The default environment in CoCalc actually does come with GRASS GIS 7.4, just without GUI. It works fine in the command line and notebooks. You can use it also from QGIS which is there with GUI, but the experience, at least with the trial, is not good.
This may not be ideal for the "Try GRASS GIS", unless there are some additions streamlining the start, but it is hopeful for actually using GRASS GIS.
Note that you can run CoCalc on your own, but I have not tried that yet (needs 15 GB just to get started). At least significant part of it is open source (it is not clear to me if 100%).
Vaclav
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20190816/b2085151/attachment.html>
