[GRASS-dev] Random selection of a given number of points/pixels per class
Anna Petrášová kratochanna at gmail.com
Fri Aug 30 11:47:29 PDT 2019
r.sample.category in addons seems like what you want?
On Fri, Aug 30, 2019 at 3:59 AM Stefan Blumentrath <
Stefan.Blumentrath at nina.no> wrote:
> Dear devs,
> Recently, I was trying to generate a fixed number of random points per
> class in a vector or raster map.
> So I looked at both v.random and r.random. However, neither seemed to give
> me the desired result:
> v.random with restrict option seems to generate points per area even if
> areas belong to the same class and share the same cat value.
> r.random does not have a restrict option.
> So I ended up writing a small script that basically loops over the classes
> and extracts n points/pixels per class from a input raster map. My question
> now is did I overlook some less obvious feature of v.random or r.random?
> If not I might create a small wrapper addon…
> Cheers
> Stefan
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20190830/47a3254d/attachment.html>
