[GRASS-dev] i.sentinel improvements
Roberta Fagandini robifagandini at gmail.com
Wed Feb 13 06:02:20 PST 2019
Il giorno mar 12 feb 2019 alle ore 11:35 Luca Delucchi <lucadeluge at gmail.com>
ha scritto:
> On Mon, 17 Dec 2018 at 10:38, Luca Delucchi <lucadeluge at gmail.com> wrote:
> > Hi all,
> Hi devs,
Hi Luca,
> > - i.sentinel.preproc add capability to compute topographic correction
> > using the following prcedure
> done in r74080, please test it
Unfortunately I have no time to test it in the next days but I will as soon
as possible.
I took a look at the interface and I saw a new text form for the output
suffix name..if the -c flag is checked, does the module create two
different output (13 atmospherically corrected bands and 13 topographically
corrected bands)?
maybe only one output (i.e. 13 bands to which both corrections are applied)
would be better.
> ciao
> Luca
ciao
Roberta
> www.lucadelu.org
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20190213/1dd69dff/attachment.html>
