[GRASS-dev] [GRASS GIS] #3763: db.out.ogr Fails with bogus overwrite error
GRASS GIS trac at osgeo.org
Wed Feb 27 01:52:42 PST 2019
 Reporter:  micha        |      Owner:  grass-dev@…
     Type:  defect       |     Status:  new
 Priority:  normal       |  Milestone:
Component:  Database     |    Version:  unspecified
 Keywords:               |        CPU:  Unspecified
 Platform:  Unspecified  |
 The current script for db.out.ogr tests for existence of a file named as
 <input>.dbf. If the file exists and overwrite is not specified, the script
 exists. This test is performed even if the format is not **dbf**.  So all
 of the other formats will fail if such a dbf file already exists, even
 though those formats do not touch the dbf file.
 For the case of dbf output the script deletes all existing shapefile
 components (*.shp, *.shx) so the test is certainly necessary for dbf
 format. But I think it is unnecessary for the other formats.
 Attached is a suggested diff.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3763>
