[GRASS-dev] Errored: GRASS-GIS/grass-ci#3299 (master - 12c0c66)
Markus Neteler neteler at osgeo.org
Thu Feb 28 07:12:46 PST 2019
On Thu, Feb 28, 2019 at 10:29 AM Travis CI <builds at travis-ci.org> wrote:
> GRASS-GIS / grass-ci
> master
> Build #3299 has errored
> 8 mins and 32 secs
> Markus Metz
> 12c0c66 CHANGESET →
> v.in.ogr: set spatial filter to correct geometry field if geom option is given
> git-svn-id: https://svn.osgeo.org/grass/grass/trunk@74137 15284696-431f-4ddb-bdfa-cd5b030d7da7
The failure seems to be Travis/Ubuntu related?
Worker information
hostname: 03539aae-cde3-4157-ab0e-7c45dce06f70 at 1.production-2-worker-org-gce-hlxz
version: v6.2.0
https://github.com/travis-ci/worker/tree/5e5476e01646095f48eec13196fdb3faf8f5cbf7
instance: travis-job-b5e9f751-2d4c-43f7-8401-3b5587b0fe1b
travis-ci-garnet-trusty-1512502259-986baf0 (via amqp)
startup: 6.43601241s
system_info
Build system information
Build language: c
Build group: stable
Build dist: trusty
Build id: 499699291
Job id: 499699292
Runtime kernel version: 4.4.0-101-generic
travis-build version: 6af6dd723
Build image provisioning date and time
Tue Dec 5 19:58:13 UTC 2017
Operating System Details
Distributor ID: Ubuntu
Description: Ubuntu 14.04.5 LTS
Release: 14.04
Codename: trusty
git.checkout
78.78s$ git clone --depth=50 --branch=master
https://github.com/GRASS-GIS/grass-ci.git GRASS-GIS/grass-ci
Cloning into 'GRASS-GIS/grass-ci'...
remote: Enumerating objects: 8437, done.
remote: Counting objects: 100% (8437/8437), done.
remote: Compressing objects: 100% (7338/7338), done.
remote: Total 8437 (delta 1269), reused 5543 (delta 942), pack-reused 0
Receiving objects: 100% (8437/8437), 48.22 MiB | 669.00 KiB/s, done.
Resolving deltas: 100% (1269/1269), done.
$ cd GRASS-GIS/grass-ci
$ git checkout -qf 12c0c66cf39dcff5789170c2661de06bf0c8f241
Setting environment variables from .travis.yml
$ export CFLAGS="-Werror=implicit-function-declaration"
$ export TRAVIS_COMPILER=gcc
$ export CC=gcc
$ export CC_FOR_BUILD=gcc
$ gcc --version
gcc (Ubuntu 4.8.4-2ubuntu1~14.04.3) 4.8.4
Copyright (C) 2013 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
7.17s$ ./.travis/$TRAVIS_OS_NAME.before_install.sh
gpg: keyring `/tmp/tmpale265_o/secring.gpg' created
gpg: keyring `/tmp/tmpale265_o/pubring.gpg' created
gpg: requesting key 314DF160 from hkp server keyserver.ubuntu.com
gpg: /tmp/tmpale265_o/trustdb.gpg: trustdb created
gpg: key 314DF160: public key "Launchpad ubuntugis-stable" imported
gpg: Total number processed: 1
gpg: imported: 1 (RSA: 1)
OK
W: http://ppa.launchpad.net/couchdb/stable/ubuntu/dists/trusty/Release.gpg:
Signature by key 15866BAFD9BCC4F3C1E0DFC7D69548E1C17EAB57 uses weak
digest algorithm (SHA1)
W: An error occurred during the signature verification. The repository
is not updated and the previous index files will be used. GPG error:
https://packagecloud.io/github/git-lfs/ubuntu trusty InRelease: The
following signatures couldn't be verified because the public key is
not available: NO_PUBKEY 6B05F25D762E3157
W: Failed to fetch
https://packagecloud.io/github/git-lfs/ubuntu/dists/trusty/InRelease
The following signatures couldn't be verified because the public key
is not available: NO_PUBKEY 6B05F25D762E3157
E: Failed to fetch
http://us-east-1.ec2.archive.ubuntu.com/ubuntu/dists/trusty-updates/main/binary-i386/Packages.gz
Hash Sum mismatch
W: Some index files failed to download. They have been ignored, or old
ones used instead.
The command "./.travis/$TRAVIS_OS_NAME.before_install.sh" failed and
exited with 100 during .
Looks like that an old Ubuntu is used here?
Markus
