[GRASS-dev] Unable to install manual for add-on r.estimap.recreation under Windows
Stefan Blumentrath Stefan.Blumentrath at nina.no
Mon Jan 14 06:03:29 PST 2019
A first swift answer:
Currently, making an addon available in QGIS is quite similar comparing the options GRASS plugin and processing. In both cases you will have to redefine the GUI in either txt or xml.
That has been a design choice in QGIS (as modules were supposed to be simplified in QGIS).
That was one thing that Radek was trying to address when he started the GSoC project to overhaul GRASS integration in Processing for QGIS 3 (if I remember correctly). But this is unfinished work I am afraid...
Cheers
Stefan
-----Original Message-----
From: Nikos Alexandris <nik at nikosalexandris.net>
Sent: mandag 14. januar 2019 14:44
To: Stefan Blumentrath <Stefan.Blumentrath at nina.no>
Cc: GRASS developers list <grass-dev at lists.osgeo.org>; Helmut Kudrnovsky <hellik at web.de>
Subject: Re: [GRASS-dev] Unable to install manual for add-on r.estimap.recreation under Windows
A few more hooks:
1. Having the add-on installed via a GRASS GIS session, using `g.extension` (not from within QGIS), expectedly it would be available from within the "GRASS Shell" under QGIS' GRASS plugin.  However, trying to launch the script from this "GRASS Shell" won't work?  Different environment variable settings I guess.
2. Performing the installation in QGIS' GRASS Shell, ends up with the warnings about the GRASS_ADDON_BASE variable, the ones I mentioned earlier in this thread.
What is a/the recommended way to proceed on this?
A request for comments:
Weeks ago, I received from Médéric Ribreux detailed instructions on how to build an entry for a GRASS GIS add-on in QGIS' Processing toolbox. I will load these somewhere in the Wiki or in trac.  Nevertheless, I decided to go the "GRASS plugin" way, rather than the "Processing"
toolbox.  The reason is that creating the interface for Processing is a lot of work as the add-on itself is quite big.  Important updates in the script itself would require to re-work on its interface for QGIS'
Processing. Using the "GRASS plugin" is way easier as it only requires to update the QGIS-GRASS module configuration file (in other words: the file named after the add-on's name with the extension .qgm).
My concern is how to achieve/ensure the add-ons inclusion under the GRASS plugin?  I recall Stefan's advise on this that I would need to write a routine to perform the proper file-copy actions.
Would you please share your thoughts on this?
To-do:
- some left-over work related with the '@MapsetName' part of map names
  when using the GUI.  I remember that `r.mapcalc` does not like this
  and it is required to do some "manual" work in the script to take care
  of it.
- update the manual.
- complete the QGIS-GRASS module configuration file
Thank you, Nikos
