[GRASS-dev] [GRASS-SVN] r73973 - in grass/trunk/testsuite: . examples
Vaclav Petras wenzeslaus at gmail.com
Sat Jan 19 10:56:05 PST 2019
On Fri, Jan 18, 2019 at 12:33 AM <svn_grass at osgeo.org> wrote:
> Author: neteler
> Date: 2019-01-17 21:33:12 -0800 (Thu, 17 Jan 2019)
> New Revision: 73973
> Added:
>    grass/trunk/testsuite/examples/
>    grass/trunk/testsuite/examples/test_framework_GRASS_GIS_with_NC.sh
> Removed:
>    grass/trunk/testsuite/test_framework_GRASS_GIS_with_NC.sh
> Log:
> test_framework_GRASS_GIS_with_NC.sh: moved into 'examples/' subdir to
> prevent from undesired execution in online testsuite
Just to be clear here, the tests running at fatra.cnr.ncsu.edu use
basically what is in the documentation [1], i.e. what is in
test_framework_GRASS_GIS_with_NC.sh. If test_framework_GRASS_GIS_with_NC.sh
would be directly in testsuite dir, it will attempt to execute itself on
any computer (through the code and rules in the gunittest package).
[1]
https://grass.osgeo.org/grass76/manuals/libpython/gunittest_running_tests.html#example-bash-script-to-run-be-used-as-a-cron-job
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20190119/09b28f31/attachment-0001.html>
