[GRASS-dev] [GRASS GIS] #3744: Vector query error
GRASS GIS trac at osgeo.org
Wed Jan 30 10:57:56 PST 2019
 Reporter:  balagates                |      Owner:  grass-dev@…
     Type:  defect                   |     Status:  new
 Priority:  normal                   |  Milestone:
Component:  wxGUI                    |    Version:  svn-releasebranch76
 Keywords:  vector query error JSON  |        CPU:  OSX/Intel
 Platform:  MacOSX                   |
 For some vector elements I get an error
 Failed to query vector map(s) <mrds_id at brett>. Check database settings and
 topology.
 Reason: ""}}]}]}]}
 ScriptError: v.what output is not valid JSON format:
 Within this vector other points query successfully.  My vector mrds_id is
 Mineral Resource Data System records for mines in Idaho.  Within Grass the
 data is in a sqlite database.  Using sqlitebrowser I see no obvious
 problems on elements that generate query errors.
 I suspect the failure is either related to 1) the length of the vector
 info (number of elements, number of characters, etc) or 2) some special
 characters within the vector info (maybe parenthesis).  The failure
 happens on maybe 10% of the vector points.
 A picture of the error is attached
Ticket URL: <https://trac.osgeo.org/grass/ticket/3744>
