[GRASS-dev] [GRASS GIS] #3863: epsg file missing in GRASS 7.6.1 stable
GRASS GIS trac at osgeo.org
Tue Jul 2 06:45:10 PDT 2019
  Reporter:  Luigi Ponti         |      Owner:  grass-dev@…
      Type:  defect              |     Status:  new
  Priority:  normal              |  Milestone:  7.6.2
 Component:  Projections/Datums  |    Version:  svn-releasebranch76
Resolution:                      |   Keywords:  epsg
       CPU:  OSX/Intel           |   Platform:  MacOSX
Changes (by Luigi Ponti):
 * cc: Luigi Ponti (added)
Comment:
 Replying to [comment:1 mmetz]:
 > Replying to [ticket:3863 Luigi Ponti]:
 > > epsg file appers to be missing in GRASS 7.6.1 stable for mac
 > > from
 > > /Applications/GRASS-7.6.app/Contents/Resources/share/proj
 > > installed from bundled binaries at
 > > http://grassmac.wikidot.com/downloads
 > The epsg file is missing because the bundle uses proj-6.0.0 which no
 longer has an epsg file.
 > GRASS 7.6 is not compatible with proj-6+, please rebuild with proj-5.x.
 Thanks and my apologies -- I suspected something like that but was unable
 to figure it out.
 (I did something really wrong which appears to work, however: copied epsg
 from another GRASS 7.4.1 precompiled bundle installation from the same
 source I had on the same machine.)
 I now see it in release notes for proj-6.0.0 that all CRS stuff in the
 proj.db SQLite3 database file:
 https://proj.org/news.html#id41
 I wonder why the bundle was built with an incompatible proj-6 libary -- it
 that going to break a lot of GRASS functionality other than the missing
 epsg file?
 Should I close the bug as it is apparently not a bug?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3863#comment:2>
