[GRASS-dev] error in v.overlay: Unable to write spatial index. Wrong node position
Markus Metz markus.metz.giswork at gmail.com
Mon Jun 10 12:39:31 PDT 2019
On Mon, Jun 10, 2019 at 6:12 PM Moritz Lennert <mlennert at club.worldonline.be>
wrote:
> Hi,
> I just came across this error:
> ERROR: Unable to write spatial index. Wrong node position (950329504) in
>         file (should be 950333637).
> ERROR: Clipping steps failed. Check above error messages and see following
>         details:
>         Module run None ['v.overlay', 'binput=temp_30311', 'operator=and',
>         'olayer=0,1,0', 'ainput=sq_batiments',
>         'output=walous_temp_batiment_tile_18980'] ended with error
>         Process ended with non-zero return code 1. See errors in the
(error)
>         output.
> Any hint of what this might mean ? Should I file a bug report ?
That means there was an error while writing out a spatial index, the file
size of the file holding the partially written out spatial index is smaller
than expected. Is this error reproducible on a different partition/file
system? Can you provide test data to reproduce?
Markus M
> Moritz
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20190610/f77f7329/attachment.html>
