[GRASS-dev] [GRASS GIS] #2048: i.pansharpen limited to 8-bit imagery
GRASS GIS trac at osgeo.org
Wed Mar 6 05:24:28 PST 2019
  Reporter:  Nikos       |      Owner:  grass-dev@…
  Alexandris             |
      Type:  defect      |     Status:  new
  Priority:  normal      |  Milestone:  7.6.1
 Component:  Imagery     |    Version:  svn-trunk
Resolution:              |   Keywords:  i.pansharpen, sharpening, fusion,
                         |  brovey, ihs, pca, 8-bit
       CPU:  All         |   Platform:  Unspecified
Comment (by cmbarton):
 Niko, I'm not sure that much of the code--or assumptions underlying the
 pan sharpening--would work or make sense for bit depth <8.
 I can check of course. The main reason to have user input for bit depth is
 to be able to calculate the potential raster value range to rescale to 8
 bit for processing. This still assumes an integer raster rather than a
 floating point one.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2048#comment:31>
