[GRASS-dev] [GRASS GIS] #3392: t.register: encoding error
GRASS GIS trac at osgeo.org
Tue May 7 00:22:31 PDT 2019
  Reporter:  mlennert     |      Owner:  grass-dev@…
      Type:  defect       |     Status:  closed
  Priority:  normal       |  Milestone:  7.2.4
 Component:  Temporal     |    Version:  svn-trunk
Resolution:  fixed        |   Keywords:  t.register encoding
       CPU:  Unspecified  |   Platform:  Unspecified
Changes (by mlennert):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 Replying to [comment:41 veroandreo]:
 > Replying to [comment:40 mlennert]:
 > > Has the work on Python 3 changed anything for this discussion, here ?
 > Testing the commands provided in comment:21 gives no error here (trunk,
 r74471M) within a python3 virtual environment. Also no errors in 76
 relbranch.
 > Tell me if I can test further, but I'd suggest closing since the
 reported issue seems to be gone.
 Thanks a lot for testing. As it works for you, I'm closing. We can reopen
 if needed.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3392#comment:42>
