[GRASS-dev] [GRASS GIS] #3843: cartographic composer only previews and outputs in profile aspect (no landscape)
GRASS GIS trac at osgeo.org
Fri May 10 05:27:15 PDT 2019
landscape)
 Reporter:  cmbarton                            |      Owner:  grass-dev@…
     Type:  defect                              |     Status:  new
 Priority:  normal                              |  Milestone:
Component:  wxGUI                               |    Version:  svn-
                                                |  releasebranch76
 Keywords:  cartographic composer, aspect mode  |        CPU:  Unspecified
 Platform:  MacOSX                              |
 I just discovered that the cartographic composer will not create a preview
 or output PDF in landscape (horizontal) mode. You can select landscape for
 composing the map. But when you go to preview or output, it reverts to
 profile (vertical) mode--cutting off map features.
 FWIW, it seems like landscape mode should be the default for maps anyway.
 But in any case, the preview and PDF output should respect the chosen
 aspect dimensions and ratios.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3843>
