[GRASS-dev] [GRASS GIS] #3837: OSGeo4W winGRASS77svn - startup error: TypeError: endswith first arg must be bytes or a tuple of bytes, not str
GRASS GIS trac at osgeo.org
Sat May 11 08:52:17 PDT 2019
  Reporter:  hellik       |      Owner:  grass-dev@…
      Type:  defect       |     Status:  new
  Priority:  blocker      |  Milestone:  7.8.0
 Component:  Python       |    Version:  svn-trunk
Resolution:               |   Keywords:  python3, py3, wingrass
       CPU:  Unspecified  |   Platform:  MSWindows
Comment (by pmav99):
 OK, I see what is going on now.
 You are using Python 3.7. As a a result the {{{shutil_which}}} name is
 [https://github.com/GRASS-GIS/grass-
 ci/blob/a26ceefdc4e14edc0529b90c4d92c0122b6a4d0e/lib/python/script/core.py#L230-L231
 an alias] to [https://docs.python.org/3/library/shutil.html#shutil.which
 shutil.which] function
 [https://github.com/python/cpython/blob/79efbb719383386051c72f2ee932eeca8e033e6b/Lib/shutil.py#L1293
 defined] in the standard library.
 On Python 2 though, shutil_which is the function [https://github.com
 /GRASS-GIS/grass-
 ci/blob/a26ceefdc4e14edc0529b90c4d92c0122b6a4d0e/lib/python/script/core.py#L160
 defined] in {{{scripts/core.py}}}.
 This is why there is this difference. The function in scripts.core is
 never executed in Python 3.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3837#comment:12>
