[GRASS-dev] pywin32 missing
Anna Petrášová kratochanna at gmail.com
Wed May 15 13:10:39 PDT 2019
Did you compile it with those local changes? It needs to be compiled to
create the xml files.
On Wed, May 15, 2019 at 3:56 PM Helmut Kudrnovsky <hellik at web.de> wrote:
> Anna Petrášová wrote
> > Hi,
> > I am testing some changes in Python library on Windows and when I get
> over
> > the current problem, I run into that I can't import win32file in
> > core/gcmd.py. Some problem with packaging?
> applied locally your commits (r74480), I get:
> C:\>grass77svn --text
> Starting GRASS GIS...
> WARNUNG: Sperren gleichzeitiger Zugriffe auf ein Mapset ist unter Windows
>          nicht möglich.
> Cleaning up temporary files...
>           __________  ___   __________    _______________
>          / ____/ __ \/   | / ___/ ___/   / ____/  _/ ___/
>         / / __/ /_/ / /| | \__ \\_  \   / / __ / / \__ \
>        / /_/ / _, _/ ___ |___/ /__/ /  / /_/ // / ___/ /
>        \____/_/ |_/_/  |_/____/____/   \____/___//____/
> Welcome to GRASS GIS 7.7.svn (r74474M)
> GRASS GIS homepage:                      https://grass.osgeo.org
> This version running through:            Command Prompt
> (C:\WINDOWS\system32\cmd.exe)
> Help is available with the command:      g.manual -i
> See the licence terms with:              g.version -c
> See citation options with:               g.version -x
> Start the GUI with:                      g.gui wxpython
> When ready to quit enter:                exit
> Microsoft Windows [Version 10.0.17763.475]
> (c) 2018 Microsoft Corporation. Alle Rechte vorbehalten.
> C:\>g.gui wxpython
> Starte <wxpython> GUI im Hintergrund. Bitte warten Sie ...
> C:\OSGEO4~1\apps\grass\grass77/gui/wxpython/wxgui.py:101:
> DeprecationWarning: Yield() is deprecated
>   wx.Yield()
> Traceback (most recent call last):
>   File "C:\OSGEO4~1\apps\grass\grass77/gui/wxpython/wxgui.py", line 106, in
> OnInit
>     workspace=self.workspaceFile)
>   File "C:\OSGEO4~1\apps\grass\grass77\gui\wxpython\lmgr\frame.py", line
> 131, in __init__
>     self._moduleTreeBuilder =
> LayerManagerModuleTree(message_handler=add_menu_error)
>   File "C:\OSGEO4~1\apps\grass\grass77\gui\wxpython\lmgr\menudata.py", line
> 68, in __init__
>     message_handler=message_handler)
>   File "C:\OSGEO4~1\apps\grass\grass77\gui\wxpython\core\menutree.py", line
> 71, in __init__
>     xmlTree = etree.parse(filename)
>   File "C:\OSGEO4~1\apps\Python37\lib\xml\etree\ElementTree.py", line 1197,
> in parse
>     tree.parse(source, parser)
>   File "C:\OSGEO4~1\apps\Python37\lib\xml\etree\ElementTree.py", line 598,
> in parse
>     self._root = parser._parse_whole(source)
> xml.etree.ElementTree.ParseError: no element found: line 1, column 0
> OnInit returned false, exiting...
> best regards
> Helmut
> Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Dev-f3991897.html
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20190515/fbd12496/attachment.html>
