[GRASS-dev] svn/trac -> git/github migration plan
    Panagiotis Mavrogiorgos
    pmav99 at gmail.com
    Sun May 19 09:34:20 PDT 2019
On Sun, May 19, 2019 at 6:53 PM Martin Landa <landa.martin at gmail.com> wrote:
> Hi,
> ne 19. 5. 2019 v 17:43 odesÃlatel Markus Metz
> Ideally, you would set up the local repo such that you pull from upstream
> and push to your fork.
> This is doable with: https://stackoverflow.com/a/4523625/592289
Nevertheless, occasionally, you might want to pull from your personal fork
too. E.g. when  you want to collaborate on a feature with others. One way
to do this is to agree that the development will happen on a branch on your
own fork. It doesn't matter if you give write access to the other devs or
if they make Pull Requests to your own fork, in the end you will have to
pull those changes to your local repo. And in order to do that you will
have to again edit your remotes.
For the record, in the above example the other devs would have to add your
own personal repository as an additional remote.
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20190519/64b1437a/attachment.html>
